Is there a way to draw a rod and shelf object that clips a corner in an angled closet? I cannot see a way or any options to make the back edge of the shelf fit the wall angle. I'll add a screenshot to show what I mean. Thanks in advance for the help!
Chamfer Corner of Rod & Shelf
Posted 30 March 2021 - 06:25 PM
You may have to make the angle at least the depth of the shelf for it to work correctly. Try a few combinations of shelf and walll length until it works. As Jim said, it should auto filll the corner, but I have come across a couple of scenario's where it doesn't.
- Jim Johnson and David Johnson like this
Posted 31 March 2021 - 10:31 AM
Thanks for the responses, it looks like Keith was right. I increased the depth of the angled wall so that it extended past the front of the shelf and it matched the angle.
- Jim Johnson likes this
#7
Posted 31 March 2021 - 10:43 AM
On the flip side, is there a way to make it stop as a normal shelf on an angled wall? Mine always auto fills the corners, but sometimes I don’t want it to.
As soon as I get close, it fills in.
Any suggestions?
I think if you stop the shelf just a bit shy of the corner it will keep it square. If that doesn't work, place a hidden wall (set so it doesn't show in 3D or print) where you want it to end.
#9
Posted 01 April 2021 - 09:49 AM
I don't waste time on tweaking, I explode the shelf and change the lineweights....done! Works great unless Softlist needed for shelving or need to show 3d.
- Mark Petri likes this
