Group Lines
#1 David Johnson
David Johnson
  • 74 posts
  • LocationSioux Falls, SD
Posted 18 May 2021 - 11:18 AM
I noticed this was brought up in a 2018 post, but does anyone know if this has been incorporated into SP2022? I would love to be able to group lines together, basically creating a symbol, but without having to go through the actual symbol creation process, similar to AutoCAD's block command.
*EDIT* I have tried using the group box command, but when I try to move the object afterwards, it ends up only moving the line segment that I select instead of moving the entire group together. Am I doing something wrong?
  • Jon Davis likes this
#2 Jon Davis
Jon Davis
  • 541 posts
Posted 18 May 2021 - 11:22 AM
that would be handy. I never use the group command b/c when I first tried I never figured out how it worked... so I just quit trying.
#3 Henry Buckner
Henry Buckner
  • 342 posts
Posted 18 May 2021 - 11:42 AM
When you select the "Move" command, a status bar appears. It has a button that says "Group" beside the one that says "Attach". If you
select the "Group" button and move an item in the group, the group will move.
#4 John Jones
John Jones
  • Administrators
  • 251 posts
Posted 18 May 2021 - 12:06 PM
SoftPlan | Selection Sets - YouTube is a more powerful tool than Group.
#5 David Johnson
David Johnson
  • 74 posts
Posted 18 May 2021 - 12:53 PM
Henry - Thanks! I knew I had to be missing something.
John - I appreciate the video. I have used control to select multiple objects, I had hoped that there was a way to single click select and move groups of lines. I just didn't realize there was a Group button to move previously grouped objects.
Thanks for the help guys!
  • 5,102 posts
Posted 18 May 2021 - 03:29 PM
Maybe a more powerful tool, but it doesn't do exactly the same thing ... I use both extensively ... each one has it's uses. I use group to move details round on drawing sheets. When multiple items need to be arranged selecting just one items in the group is easier than trying to multi-select items which may be overlapping. It's easier to throw 5 or 6 details on a page and rearrange them with group ... of course they have had to be defined as a group when they were originally created.
  • John Coyle likes this
