Hello I need some help finishing the wall edge and side. This exterior wall extends up passed the roof. Anyway to fix this?
How to finish tall exterior walls
Posted 30 May 2021 - 07:27 AM
You should create a new wall type w/ sidings on both sides. On the end i'd use a rectangular solid or something to simulate trim board or LP trim....or copy your stucco finish if you'd like.
Posted 30 May 2021 - 07:33 AM
I would maybe suggest, edit that wall, and put the height at say 5', then in edit do "fit to roof". if this does it, then turn off cleanup for this wall.
If it still goes up to the upper roof, go to roof mode, and "move " that upper roof to the side. then repeat the first part and it will probably fit to
to the lower roof OK. Then turn cleanup off for that wall.
go move the upper roof back in place.
Posted 30 May 2021 - 11:41 AM
Check out the link."..Got it....found this Sketchup model, installed in SP and then applied....bingo a very nice looking corner....and when in 3d mode, move the symbol to the correct position...
https://3dwarehouse....ner?tab=general
Harlon G. " Buddy " Suttle
casekc49@gmail.com
CELL: 913-339-6242
#5
Posted 30 May 2021 - 12:32 PM
That link doesn't appear to work Harlon.
Posted 30 May 2021 - 05:13 PM
If you want to fix that end of the wall that is hollow, you can go to Options- extraction options and turn the wall framing on,
then go to edit the wall and make it a different wall type from any used in the project, and edit the new wall definition to be stucco in and out.
then in 3D select "surface copy/paste" and make the 2x4 a stucco surface and any other little pieces of sheathing etc. you might see.
Maybe
Seems i saw something in 2020 or maybe was 2022 that you can select to close the end of the wall. might have been a wish?
Also tagged with one or more of these keywords: wall edge, exterior wall, tall exterior wall
SoftPlan →
General Questions →
Wall coverings on the inside of an exterior wall?Started by Robyn Pike , 06 Jul 2022 wall covering, exterior wall |
