I am trying to produce renderings in soft plan, I have searched YouTube but cannot find the "render" icon?
Where do I go to hit render?
Posted 27 July 2021 - 09:09 PM
Be sure in the navigation rolldrown that the plan you want to Render is at the top under Model, if not drag and drop it up there..
then in the same navagation rolldown, go down to where you see 3D views, and select Texture or ray trace, this will open up a 3D rendering look at the drawing that you put up into the model at top of navigation rolldown.
Depending on how much power your computer has as to how fast the rending will take.
From this point you will need to learn things about the program, but you will probably want to, once you see the treasure at the end of the rainbow,
