Walk-Out Basement Wall
#1 James Quesenberry
James Quesenberry
  • 126 posts
  • LocationSouth West Virginia
Posted 19 August 2015 - 09:46 AM
I created a walk-out basement wall (Which I'm not sure will work to start with.) and need to give it a negative offset so that it lines up with the top of the foundation wall. My issue is that on the edit wall information tabs this option is grayed out and not available. How do I change that please?
Thank you,
#2 Yvon Gonthier
Posted 19 August 2015 - 10:13 AM
Type in your offset in the box above then the option to select up or down will appear.
#3 James Quesenberry
James Quesenberry
  • 126 posts
Posted 19 August 2015 - 10:36 AM
I'm an idiot Yvon! My mind doesn't work that way. It was my assumption that the offset had to be selected before I could input a dimension and I wasn't smart enough to input a dimension to see what would happen. Thank you though!
