3D view problems
#1 Doug Bogart
Doug Bogart
  • 2 posts
Posted 23 August 2021 - 05:20 PM
Probably a simple answer to this question, I'm pretty new to Softplan. I've created my main floor drawing and the second floor, stacked them but the main floor keeps showing up as a basement in the textured 3D view. I can't get the main floor drawing on grade. Any help appreciated.
Doug B
#2 Fred Russell
Fred Russell
  • 611 posts
Posted 23 August 2021 - 05:50 PM
Open "setup options", usually on tool bar and uncheck auto horizon, and then recheck and maybe it will fix it's self.
Should you have drawin in a site plan property, you would maybe need another approach, but if not do the above, usually fixes it
or when you check auto horizon, sometimes you can check the box there and do something like 8' and select down.
It'll shake loose
#3 Jim Johnson
Jim Johnson
  • 289 posts
Posted 24 August 2021 - 10:07 AM
Make sure you didn't inadvertently add a sill plate to your second floor.  Auto Horizon will reference the highest sill plate.
  • John Jones and Stephan Page like this
#4 Doug Bogart
Doug Bogart
  • 2 posts
Posted 24 August 2021 - 10:07 PM
Thanks, y'all helped!
