Custom Windows
8 replies to this topic
#1 Ben Ginther
Ben Ginther
  • 141 posts
  • LocationSaskatchewan
Posted 10 September 2021 - 11:22 AM
When I make my own openings, I use a dashed line for the purpose of glazing but when I use those windows I have the dashed line in my elevations. Can I avoid that?
#2 Richard Rubinski
  • 611 posts
Posted 10 September 2021 - 11:57 AM
Why not use a standard casement window uncheck product code edit it to the size you want then click on add product code then it will be in your system for future projects
  • John Jones likes this
#3 Henry Buckner
Henry Buckner
  • 342 posts
Posted 10 September 2021 - 12:05 PM
When you make the window, block copy the bead lines a set distance away from the window. Edit the copied lines and change them to the glazing style then block move the copied lines back to the window. The bead lines will hide them.
#4 Ben Ginther
Ben Ginther
  • 141 posts
Posted 10 September 2021 - 01:10 PM
Thank you Henry! That works just great.   Richard, this window is 25 x 63 and if I edit that to the right size and display 2 horizontal and 2 vertical sections the section-borders are too wide. This is a Marvin Elevate window with divided lights.
#5 Richard Rubinski
  • 611 posts
Posted 10 September 2021 - 01:48 PM
Do you need a wider grille?
#6 Ben Ginther
Ben Ginther
  • 141 posts
Posted 11 September 2021 - 05:16 PM
A wider grille works well but it has to be done at the project or drawing level and applies to all windows.
#7 Richard Rubinski
  • 611 posts
Posted 12 September 2021 - 10:53 AM
I wonder if you could add a building option to the window with a wider grille from the rest of the the windows in the house
#8 Keith Almond
  • 5,101 posts
Posted 12 September 2021 - 12:26 PM
The grille width setting is (as far as I'm aware) a global drawing variable, and will affect ALL grilles.
#9 Richard Rubinski
  • 611 posts
Posted 12 September 2021 - 01:01 PM
It would be nice if in building options you could select another drawing template so you could make that change or make the grille width editable when you edit the window.
