Adjust not snapping
#1 Andrew Morrison
Andrew Morrison
  • 16 posts
Posted 10 February 2022 - 11:53 AM
I use cursor snap so for example when I adjust a wall to end at a perpendicular wall, it would snap to the wall if I was close/the red perpendicular snap would show. Now the red symbol appears but the wall ends slightly off the mark. Is this because of the recent update?
Thank you!
Posted 10 February 2022 - 11:59 AM
Check the wall join settings.
  • Andrew Morrison likes this
#3 Andrew Morrison
Andrew Morrison
  • 16 posts
Posted 10 February 2022 - 12:14 PM
So turning on the tolerances helps, but do I have to do that for every new wall?
#4 Andrew Morrison
Andrew Morrison
  • 16 posts
Posted 10 February 2022 - 01:47 PM
Ah I figured it out, the snapping started working again when I went into System Options, Wall Trace Line, and changed both to "Center."
Thank you!
