I have a deck with a solid surface. The finish is chosen as plywood. In the plan set, the deck surface has a slight gray shading. What controls this shading? The wall shading is easy as it is controlled in the wall definition but for the life of me, I can't find what controls the deck surface shading.
Deck Finish Shading
Started by
Kris Marteinsson
, Feb 25 2022 08:47 AM
#6
Posted 25 February 2022 - 12:59 PM
Bill,
Played around with this a bit. The setting seems to apply only to the lines forming the edge of the deck item, not the shading. The 6" wide boards get the colour applied to the edges but the shading stays the same whether I have the pen set to black or gray. Only option which seems to be available is to turn the shading off or on.
