I want to define an exterior wall that only shows the studs in 2D like a partition wall where the drywall is there but isn't depicted on the drawing. Using that as an example for my settings on a 2x6 siding wall I unchecked Inside/Outside Visible on the materials I don't want to see. Unfortunately, I didn't get the results I was expecting. Can this be done with exterior walls?
Define Wall Help
Posted 06 September 2015 - 05:07 PM
Can you post a screen shot of your wall definition. it should certainly be possible.with any wall.
Posted 07 September 2015 - 01:25 PM
with the "3d drawing open" / any mode
try going to
File / material file / load / stick framing - click generate
see what happens.
note:
or with softview open
go to / options / extraction options /
framing - and check the box left of "FRAMING"
it should put a check in each of the individual
framing area boxes.
if needed, you might have to UNcheck the "display"
by the materials that cover the framing.
they might not have the display unchecked.
note: you can also go into / options / material
and check the materials to see if their unchecked.
if your not confused now, you will be after reading
what i have to say.
bottom line:
just make sure the extraction options for framing
has the box checked to the left of the areas you
want to see the framing in 3d.
note: you'll also have to make sure
that materials covering the framing need
to be UNchecked so they don't show in 3d.
v10 to future 2016+
