Section Line Editing
#1 Kris Marteinsson
Kris Marteinsson
  • 89 posts
  • LocationSalmon Arm, BC
Posted 04 April 2022 - 03:20 PM
Section lines auto number with letters. Is there any control over this? I use letters in one direction and numbers in the other direction. The auto numbering also seems to be a problem when you insert a new section line between two existing ones. I thought I could just create my own section lines which would look like I want but can't see a way to have an object appear in all plan views like section line will.
#2 Mark Petri
  • 1,506 posts
Posted 04 April 2022 - 03:59 PM
I use my own symbols & lines and place them all on their own layer. I can set that layer to show up in whatever mode I want. I don't like the way SP does section lines at all. I place the SP section lines and then turn off visibility once I have them where I want. Then my lines and symbols show up. Only problem is I have to copy and paste to other drawings in the model stack. And, I have to remember to change at each drawing if I make a change.
#3 Kris Marteinsson
Kris Marteinsson
  • 89 posts
Posted 04 April 2022 - 04:39 PM
"Only problem is I have to copy and paste to other drawings in the model stack. And, I have to remember to change at each drawing if I make a change."
I thought about your method and was hoping for a method which doesn't require attending to all plan views if there is a change. Too bad you can't give an object the visibility properties of a section line which seems to be the only object capable of appearing in all plan views.
#4 Mark Petri
  • 1,506 posts
Posted 04 April 2022 - 05:10 PM
Yep, would be nice if we could do that or just have more control over such things like section lines.
