I have some beams which seem to have a mind of their own.
1) Place a beam which rests on two posts.
2) Place another beam which is perpendicular to the first beam but rests on top of the first beam.
3) CLEANUP IS TURNED OFF. End projection is set to 0"
Seems to me that I should be able to adjust the beam length and not have any auto adjustment take place. This does not happen. Sometimes the beam length will adjust to the side of the post, sometimes to the other side of the post, or the middle of the post. In one case, the second beam adjusted to be level with the first beam. If cleanup is turned off, why am I getting all these automatic actions. Is there a setting I'm missing somewhere?
