Importing 2D billboard images
7 replies to this topic
#1 PAUL LADNER
PAUL LADNER
  • 77 posts
Posted 12 September 2015 - 06:26 PM
How does one import 2d billboard people from sketchup warehouse or other sources?  I tried using the same method as 3d imports, but it didn't take.
Also, any recommendations for a source of high resolution 2d images?
Paul
#2 James Quesenberry
James Quesenberry
  • 126 posts
  • LocationSouth West Virginia
Posted 14 September 2015 - 08:58 AM
Hey Paul,
When you say high resolution images what exactly are you referring to? Items in particular or texture files?
#3 randolph cohn
Posted 14 September 2015 - 12:32 PM
try
imagecels.com
or
image cels.com
or try link below
http://gfxdomain.co/...ndle-16512.html
#4 PAUL LADNER
PAUL LADNER
  • 77 posts
Posted 17 September 2015 - 10:13 AM
That was a good tip Randy.  Thanks.
But still need some help on how to import jpg.'s into SP for use as people billboards SoftView.
  • 5,094 posts
Posted 17 September 2015 - 10:35 AM
Paul,
To create a billboard symbol you would draw a plane (DRAW > SOLID > PLANE) the size that you want the final billboard to be - say 5'8" x 1'10" or whatever to suit the aspect ratio of the particular JPG.
Then create it as a symbol. CHECK the LINK TO 3D SYMBOL box and link it to the 3D Symbol Folder SHAPE and the 3d symbol 36 X 36 VERTICAL PLANE.DWG. Then add the relevant JPG as a texture on to that plane.
To use a JPG as a Texture it must be located in the C:\SoftPlan\3D\Textures\Bitmaps directory, or a subdirectory of it, otherwise, you cannot navigate to it in the texture editor.
#6 PAUL LADNER
PAUL LADNER
  • 77 posts
Posted 17 September 2015 - 10:43 AM
Keith,
Thank you.  That's exactly the information I need.  Will give it a try today.
  • 5,094 posts
Posted 17 September 2015 - 10:59 AM
You're welcome
  • 5,094 posts
Posted 17 September 2015 - 11:12 AM
One note .... in the Softplan folders that exist, it appears that all the BMP's have a blue background, and all the JPG's have a Black background. The PNG's show white, but I am assuming that they are actually transparent. PNG supports transparency where JPG and BMP does NOT. So background may be important.
I haven't tried to create a billboard symbol, so there may be some issue that you have to work round.
