Window Mulling
#1 David Kauffman
David Kauffman
  • 21 posts
Posted 09 July 2022 - 07:38 PM
How to I place a window above a window and not have the system automatically place a white space and call it a mull?
I have a window that is 6" above the first window and it automatically does that. There needs to be siding between. Also on the plan is one that is 11" above and same problem.
For poops and giggles I slid one in at 30" above with the same issue as a result.
This shouldn't be this hard.
Dave Kauffman
Bachman's Roofing, Building & Remodeling
  • ROBERT BROGAN likes this
#2 Mike Adams
Mike Adams
  • 247 posts
Posted 10 July 2022 - 03:30 AM
its not ...repetition is the key
WINDOW EDIT>HEADER>UNCHECK FROM GROUP OPENINGS ...or something to that effect
#3 Fred Dickson
Fred Dickson
  • 208 posts
Posted 10 July 2022 - 04:30 AM
You can set your openings on the System level to NOT auto join.  If you want to join them, you can do that using your drawing options/commands/tools.  I find more times then not I do not want to join the openings.
#4 David Kauffman
David Kauffman
  • 21 posts
Posted 11 July 2022 - 05:48 AM
Thank you for the responses
