I have never looked at plumbing drops good until now,
The toilet I use is showing to be 8 3/4" off the wall, via the plumbing drop reference mark.
I would assume it is repositionable. I need 12"
The program came in box at 8 3/4" off wall
Posted 01 August 2022 - 06:31 PM
You can explode the symbol and reposition the reference (plumbing drop) and then recreate the symbol. If you want it to be the exact symbol you are modifying it may be best to fully erase that symbol before recreating the new version. Otherwise just name it something different and create it with the same reference to the 3D symbol as the factory one.
Posted 01 August 2022 - 07:21 PM
Fred, I usually draw a 4" diamter circle, position the circle at desired location for toilets, shower drains etc
and then select the group and do a copy and paste on the floor layout page or wherever else the drop
location would be useful. The 8 3/4" Toilet center you mention would be the dimension to the drain for a
wall faced toilet, as you know most others are 12" to center.
