Export to DGW/DWF File - Symbols not showing up?
#1 Sean Tobin
Sean Tobin
  • 48 posts
  • LocationRaleigh North Carolina, USA
Posted 30 August 2022 - 08:01 AM
Good morning all -
I am trying to export a plan to DWG for a consultant, but when I do the export, the symbols do not show up.  This one drawing in particular is to have the Plumbing symbols, for example.
All that show up are the circles with cross lines.
Is there a setting that I could try to change this?  Is there something about the symbols I need to change?
Thank you in advance!
#2 David Zawadzki
  • 658 posts
Posted 30 August 2022 - 09:40 AM
Does this help you?
https://youtu.be/5zMmWJyJh1o
#3 Sean Tobin
Sean Tobin
  • 48 posts
Posted 30 August 2022 - 01:24 PM
Does this help you?
No, but thanks for the link anyway, I appreciate it.
#4 Tim Stockton
Tim Stockton
  • 313 posts
  • LocationWichita, KS
Posted 21 September 2022 - 03:33 PM
Check the layers in AutoCad for visibility and make sure they are turned on.  I've run into that issue in the past
