My old CAD system had extended characters that allowed us to add certain symbols to our text like a plus/minus,degree or diameter symbol. Does SP have something similar?
Thank you,
Posted 18 September 2015 - 03:00 PM
Yes, .. Softplan will respond (sort of) to the old ASCII character codes, .. (you can also check your Windows Character Map for the Fonts you use)
examples, .. Alt+0176 will give you degrees °, .. Alt+0177 results with ±, , ..
.. again some work, some don't, .. but thru the character map you can cut and paste whatever's available within your chosen font.
Posted 18 September 2015 - 08:33 PM
As Doug says some fonts are different. So check within the Character set. I personally prefer BabelMap, It gives a little bigger preview for those of us with failing eyesight. A good UNICODE font may contain a few thousand characters. Check out the characters available in ARIAL UNICODE MS.
I remember degrees ° = ALT+248 and squared ² = ALT+253, but there again I remember using the ASCII codes to draw boxes with double and single lines when the codes only went to 255.
Some common ones are:
ALT+0188 = ¼
ALT+0189 = ½
ALT+0190 = ¾
ALT=0216 = Ø
and if you really want to get creative, (if your chosen font supports them):
ALT+8539 = 1/8
ALT+8540 = 3/8
ALT+8541 = 5/8
ALT+8542 = 7/8
Although this text box doesn't support them .....
