is there a way to get the length of the stairs stringers once you get a deck layout is right i look in the report but not there
i was if there is a another way
thanks Ron
Posted 17 October 2022 - 02:17 PM
Ron,
We have this formula in SoftList to calculate the length of the stringers. Does not seem 100% accurate but close enough. Might give you something to work with.
Jon
If you require accurate stringer length use the formula below that accounts for the additional riser at the top of the run.
Posted 29 October 2022 - 03:13 PM
Hi
Try this site. It has calculations cutting lists for virtually any building component.
Very useful.
The formulas are there which can be used in softlist.
Free but he has a nominated charity if you care to donate.
