Just after sending the previous post my drawing shut down and when I got back in this is what I got. Help PLEASE!
Elevations starting to fall apart!
Posted 23 September 2015 - 08:58 PM
trying to give my 1st thoughts and the issues
1. right click on the "LEFT" full gables "fascia" or the gable itself
and uncheck 'gable provided by roof'
then right click on the wall below that gable
and click "fit to roof"
(or you might be able to regenerate and have that fix it. (hit or miss)
(you can usually click the "fit to roof" as noted above
and that's "UNcheck" > "gable provided by roof"
2. on the right odd shaped gable
right click on the gable that's up in the air and UNcheck "regenerate" and than check "regenerate" and see if that fixes it.
others will come and give other suggestions. many ways to fix the same issues.
v10 to future 2016+
Posted 23 September 2015 - 09:16 PM
and uncheck 'gable provided by roof' then right click on the wall below that gable and click "fit to roof"
I did what you said and the result was that the right gable in space shot back into it's correct location and the left gable disappeared.
Worked as Prescribed, all is well and I can't thank you enough!
Didn't get this far thank goodness.
Posted 24 September 2015 - 06:32 AM
You could have also gone to the COMMON tabs, and clicked PERFORM ITEM CLEANUP. That may have worked OR maybe in the roof plan, regenerated the roofs. Sometimes one thing works and not others.
Posted 24 September 2015 - 11:56 AM
a note to what keith suggests.:
if you have the roof providing the gable you WON'T have a "common" tab to "perform item cleanup"
If you EDIT the wall and have the wall "fit to roof" than it'll have "common" tab
and you can than "perform an item cleanup"
v10 to future 2016+
#7
Posted 25 September 2015 - 11:35 AM
It depends on if your gable finish is the same as the wall or not. Also, gable vents are easier to incorporate in a gable than a wall.It would seem to me that to eliminate the potential of something happening like I my issue you would want to always go back and set the wall to fit to roof. Thoughts?
Might represent a bit more work to adjust your section if it cuts thru the gable.
