9-Lite Exterior Doors
13 replies to this topic
#1 Stephan Page
Stephan Page
  • 91 posts
  • LocationMaine
Posted 27 December 2022 - 02:58 PM
Would anyone happen to have a 9-Lite Door 3D symbol?  I've looked on 3D Warehouse as suggested by SoftPlan, but couldn't see one.  I don't know how to use sketch-up, or I guess I could create my own.  I don't believe you can create one inside SoftPlan can we?
Thanks in advance for any help!
Posted 27 December 2022 - 09:19 PM
There's an existing nine light door ... Search "DUTCH"
#3 David Kauffman
David Kauffman
  • 21 posts
Posted 28 December 2022 - 10:32 AM
The "dutch" are 6 lite. not sure why.
#4 Ron Sirolli
Ron Sirolli
  • 262 posts
Posted 28 December 2022 - 11:02 AM
if you add A-Series Andersen French door then you can add the grill pattern as you need it
Posted 28 December 2022 - 12:39 PM
I've never been sure either (6 lights are very uncommon here), but if you uncheck product code, you can change the grille pattern - at least I seem to remember that's the way to do it ... it's been a while, since I used one, as I have a 9 light set up as standard.
#6 Wesley Penner
Wesley Penner
  • 59 posts
Posted 30 December 2022 - 06:53 AM
Keith,
While it is possible to uncheck the product code and adjust the grilles, I believe that this only works for 2d or elevations. If you would like an accurate 3d model, you would need to update the 3d model linked to this door in the system or drawing library ->Elevation openings
I am attaching a sketchup model of the softplan dutch door slab model that has been updated to have 9 lites.
  • Stephan Page likes this
#7 Wesley Penner
Wesley Penner
  • 59 posts
having trouble uploading.... This should work.
  • Mark Petri and Stephan Page like this
#8 Stephan Page
Stephan Page
  • 91 posts
  • LocationMaine
Posted 30 December 2022 - 09:33 AM
Thank you all!
#9 Keith Almond
Posted 30 December 2022 - 12:15 PM
Actually Wesley. you are right ... ish ...
I remember now that instead of updating the 3D model, I unlinked it from the dutch door, forcing the door to generate its own 3D.
#10 Stephan Page
Stephan Page
  • 91 posts
  • LocationMaine
Posted 30 December 2022 - 02:30 PM
I cannot figure out how to do that...  Any chance you could explain how?
#11 Wesley Penner
Wesley Penner
  • 59 posts
Posted 31 December 2022 - 02:01 PM
You would need to go into the elevation opening library, find the right elevation opening and uncheck the "Link to 3D Symbol" checkmark. See attached. Like Keith explained then the 3d slab will be generated by Softplan. While not as detailed a 3d this can work for well for elevations and quick 3d's.
#12 Wesley Penner
Wesley Penner
  • 59 posts
Posted 31 December 2022 - 02:05 PM
attachment problems... :angry:
  • Keith Almond and Stephan Page like this
#13 Keith Almond
Posted 31 December 2022 - 03:16 PM
Thank you Wesley.
#14 Stephan Page
Stephan Page
  • 91 posts
  • LocationMaine
Posted 03 January 2023 - 08:49 AM
Thank you Wesley!
