Hello - I'm trying to get my head around display settings. I have a custom mode called "BROCHURE". While in that mode, in the "Main Floor" view of the model, I set custom drawing settings. This included showing room names. If room names are not turned on in project settings and I then go into the drawings settings and select "use project drawing template" and hit OK, the room names do not disappear. So I have a strange condition where the drawing settings are showing that they have NOT been customized, however, they HAVE been customized because they are not showing the room names.
Some things, such as the name of modes can be changed by switching from custom drawing settings to "use porject template". But it doesn't work with room names and probably other things. Can anyone clarify what is going on here? Is there a logic to it or do I just have to memorize which things will change and which do not.
I recognize that this is not the primary way to work with Softplan, but I'd like to understand anyway. Thank you.
