Drawing Big Foot Deck Supports
#1 gary wood
gary wood
  • 98 posts
Posted 01 February 2023 - 09:57 AM
How can you draw bigfoot deck footings that are now code instead of sonotubes
#2 Matthew Dunson
Matthew Dunson
  • 167 posts
Posted 01 February 2023 - 01:41 PM
One easy way I would approach that is to import a 3D warehouse model of the footing which can be found here if I am not mistaken of the product you are referencing to:
BF#^ Bigfoot Systems Column Footing | 3D Warehouse (sketchup.com)
Import this into SoftPlan as an individual model and scale it according to your size requirements. Then use the Footing feature on each post to add a concrete base and offset the symbol to the bottom of the post footing.
#3 Philip Frank
  • 560 posts
Posted 02 February 2023 - 06:15 AM
Hi Matthew,
I don't see a "Footing " option anywhere for posts. I only see the ability to add a 'Round Pad" or " Square Pad" below the post. How do you tell Softplan to use the imported symbol?
#4 Matthew Dunson
Matthew Dunson
  • 167 posts
Posted 02 February 2023 - 08:35 AM
Hi Matthew,
Yes, you are correct! That was the wrong term I was using but it will be the Round Pad settings in the post properties. There are a few forums that explain in depth how to import custom models:
Importing Sketchup Models: Tutorial - SoftPlan 2016 - SoftPlan Users Forum
