Can someone explain how to draw angle bracing for a free standing deck
#5
Posted 04 February 2023 - 10:42 AM
Just draw a solid polygon to the spec you want for the brace. Add only that drawing (all by itself) to the model. Then save the resulting 3D DWG. Save a copy of the 3D model to the 3D library of your choice in your SoftPlan folders. Draw the line work for how it would look in plan view and then use that linework for the 2D representation to create a new symbol and link it to the 3D DWG model you exported. There are some tutorials out there on how to make your own symbols if you are unfamiliar with what to do. Also, there are some fancy braces and brackets in the existing libraries. If not too concerned about perfect 3D representation, you can also use a sloped beam to achieve the look. It works well especially if the brace is smaller than the post and beam it is attached to. Make sure you uncheck cleanup and anchor it so it doesn't move unexpectedly (although it still may do that).
#7
Posted 04 February 2023 - 12:49 PM
when you edit the beam you can check the slope button then adjust each end. Thats how I've always done it until they added the bracket feature. You should consider going to SP+ monthly...you're missing out on some good features and the monthly payment is easy
#13
Posted 04 February 2023 - 09:16 PM
I've never understood why we NEED different beams for deck beams and beams (with different options) ... In my opinion it would be much preferable to have just beams and allow alternate finishes like sidings do.
- Gary McKeon likes this
Posted 08 February 2023 - 07:10 PM
Not sure I am understanding, but I am guessing you are looking at the length in the beam edit menu. The length unfortunately is purely adjusted by using the adjust tool in plan view or 3D. You cannot type in a length. So, dimension it or set some guidelines and adjust accordingly.
