Post cap with light - symbol
Post Cap railings
#1 Thomas Parker
Thomas Parker
  • 50 posts
Posted 15 February 2023 - 10:26 AM
I couldn't seem to find a post cap with a light, so I make one with SP and imported it into the symbols 'Post Cap' library. I was feeling good about the symbol because it actually worked when added to the drawing. BUT here's the situation - when I add the the post caps in the 'Railing' they do not want to light up?
Not a big priority, but there might be an easy fix.
Thanks for viewing,
TOM
PS i tried to attach a jpg rendering of the dilemma
Attached File  Post Lt.jpg   36.35KB   1 downloads
Tom Parker
TJP Designs and Const. LLC
v10 - v2020
#2 Mark Petri
  • 1,506 posts
Posted 15 February 2023 - 11:06 AM
Once you add it to the railing does it show up as a light in electrical mode? My guess is it needs to be in the electrical symbols library in order to show as a light. I've never tried to do a symbol with a symbol inside it, but maybe that is a solution? Create it as an electrical symbol, then put that in the post cap symbol?
  • David Franz likes this
#3 Thomas Parker
Thomas Parker
  • 50 posts
Posted 15 February 2023 - 02:23 PM
Hi Mark, thanks for the suggestion, but yes I had tried that option also exactly as you had described above, and to no avail  :mellow:
Tom Parker
v10 - v2020
#4 Mark Petri
  • 1,506 posts
Posted 15 February 2023 - 04:28 PM
Might have to just put a light in it separate. Would be nice if it worked (kind of like cabinet lighting).
#5 Brent Hyndman
Brent Hyndman
  • 1,549 posts
Posted 17 February 2023 - 04:01 PM
Send the project in a ticket and we can take a look.
  • Thomas Parker likes this
#6 Thomas Parker
Thomas Parker
  • 50 posts
Posted 21 February 2023 - 03:42 PM
I wanted to circle back and let you know what SP support had to say:
"There isn’t an option to turn the light source on for a symbol being used as a Post Cap, but I’ve forwarded this onto our development team on your behalf.
I’d suggest manually adding the symbol on top of the posts using the ‘Draw>Symbol’ dialog so that the light source can be shown in 3D.
You may also want to use the ‘Edit>Surface Edit’ command in a 3D view, select the glass surface of the symbol and increase the Emissive in the Lighting tab to make it appear that the surface is emitting light."
SP Support responded within 24 hours - they're the best!
Anyways, it may be coming down the pike, and thanks Mark and Brent!
TOM
  • Mark Petri and Gary McKeon like this
Tom Parker
v10 - v2020
#7 ROBERT BROGAN
ROBERT BROGAN
  • 52 posts
Posted 27 February 2023 - 06:06 PM
HIDE A PUCK LIGHT IN THE CAP?
