If you form a hole in a floor construction you are left with an exposed edge when viewed in 3D - how do you trim this?
Trim Openings
Started by
Andrew Mitchelmore
, Feb 17 2023 10:28 AM
Posted 17 February 2023 - 11:02 AM
In order for drywall to fully cover, you must have the floor joists (all framing) in place. If you don't get the results you want, you can also use a solid cube, polygon, or drywall only wall or some other option to fill it in. I find sometimes the "add drywall" does not align the way it would actually be constructed.
