I have a slopping roof with an intersecting dormer - how can I get a ceiling to fit the dormer section?
Dormer Ceilings
Posted 23 February 2023 - 09:28 AM
Use some hidden beams or walls outside the dormer set at the same plate height as the neighboring walls (or where you want the ceiling to reference) to give a place for the hip portions of the ceiling to reference on either side of the gable. Then set the gable end either to reference the outside wall or a hidden beam just outside of the neighboring walls. If you need to stretch it out beyond the outside walls, use a hole to cut it back to the interior as you like.
- Allen McDonnell likes this
Posted 23 February 2023 - 10:49 AM
Well said Mark...Exactly how i did this.
FF remodel...so some off this is existing. Not how i would typically set it up
