When using Attic Truss command how do we create a hole for the stairs, the ceiling drywall is easy to remove when you use create hole tab on the Stairs.
But it doesnt cut out and leaves the Bottom Chord on the Attic Trusses.
Also when you create an attic space why does it seem to default about 2' in from the ends. We typically use the gable end as a framed finished wall.
I can set the width on the attic truss tab 14' typically which is great. should be a way to use the gable as an exterior finished wall.
