I have created a wall type with a small amount of stone on the front and would like to have the stone show up on the floor plan in addition to the siding. Is it possible to this?
Thank you,
Posted 15 October 2015 - 09:17 AM
Not in addition to ... to show the stone, INSTEAD of the siding, you can adjust the DISPLAY HEIGHT, so It cuts through the stone.
As a workaround you could have a NONE Material show as a single line on the line of the outside of the stone, but full height.
Personally I always adjust the DISPLAY HEIGHT to show the stone. There's less chance of anchor bolts and framing being in the wrong place on site.
Posted 29 October 2015 - 06:22 AM
Can't remember whether that is in v14 ... I suspect not. However it's here in 2016, in the wall definition.
Posted 29 October 2015 - 06:23 AM
Posted 02 November 2015 - 10:37 AM
True but your 95% would be more efficient. It would take a little getting use to but worth it. There is always a danger that some things might not work properly or be supported when your to many versions behind. Not sure for example if when you have to update to Windows 10 (or more recent of the program you're using) if it will have an impact or not?Hi, Yvon, Thanks for pointing that out. Then "Display Height" is not an option with v.14.
I keep putting off upgrading because v.14 still does 95% of what I need and it's hard to justify the cost for the extra 5%!
Bill Beatson
