I have a client who wants a couple small roofs held up with cables as shown in the attached. Can anyone give me an idea how to model the cables in SoftPlan?
How to Model Roof Cables
Posted 15 March 2023 - 02:44 PM
I would recommend using a model from the 3D warehouse as well since you can get the smaller details on the cable connections opposed to a beam inside SoftPlan (I try to go for as much detail as possible for rendering), but again there are multiple ways to achieve the same goal and I think SoftPlan has an easy process of importing Sketchup Models. You can also use the Brace function inside SoftPlan and scale it down to cable size and use solids to mimic the connection plates.
Posted 16 March 2023 - 06:40 PM
I use beams set to the right diameter with some solid cubes, polygons, or whatever makes it look decent for initial concepts. If we are going to final I will model something in SketchUp or do some details that show it better.
Posted 23 March 2023 - 07:48 AM
I used log beams and cubes in this example. The symbol is fine but if you need control over cable angle the symbol isn't the solution.
- Matthew Dunson likes this
Also tagged with one or more of these keywords: Cable, cables., roof cable, roof cables, roof
Raise Roof - Window Pediment Clearance, Heel Height, Knee WallStarted by Steve Gray , 08 Feb 2024 Roof, Knee Wall, Raise Roof and 1 more... |
Roof SettingsStarted by Mark Petri , 11 Dec 2023 Roof, Settings, Project Settings and 2 more... |
Drawing Roof PlanStarted by Bruce Schlittler , 10 Sep 2023 Visibilities, Roof |
Pointed GableStarted by Wendall Hilty , 14 Dec 2022 Gable, Roof, Angle, Pointed, edge |
SoftPlan version 2020 →
Roof Design / Cross SectionStarted by Jason Ball , 04 Dec 2022 roof, cross section and 1 more... |
