How do you add exterior crown mouldings onto beams?
Exterior mouldings around beams
Posted 29 January 2015 - 03:41 PM
Todd, Why would you create a wall to be used as a beam ..... Why don't you just create a beam? (Not criticising, just querying ... There's usually more than one way to do work arounds). Beams work much better than walls with the posts!
Posted 29 January 2015 - 05:06 PM
Interesting that INTERIORS mode CROWN will not generate on a BEAM.... BUT an INTERIORS mode BULKHEAD WILL generate on a beam...
so easy enough to add a crown profile (say, "American") to the bulkhead profiles (SYSTEM OPTIONS / FINISHING OPTIONS / BULKHEAD OPTIONS...)
the attached was draw with a "bulkhead".... with "American" profile added to the bulkhead profiles... then edit the generated crown to a larger size...
also note that 2016 will allow one click ADD DRYWALL to beams...
Posted 30 January 2015 - 09:00 AM
Hi Keith,
I had issues with the moulding not mitering at the corners when added to a beam profile. Also, I got in the habit of using walls for beams to show arches in them. The openings>arch works well for this.
also as a side note, how to we post images?
V11-V2024
