key not working
softplan key key key not working
#1 Thomas Davis
Thomas Davis
  • 301 posts
Posted 09 November 2015 - 03:18 PM
Just an FYI - incase this happens to you
My key was working fine, but then a few days ago my key started working very sporadically. I could wiggle it and get it to work, but then sometimes in the middle of working, it would just disconnect.
This started happening more and more to where the key was almost inoperable. I looked at the key closer and noticed that it did not appear to plug all the way into the USB port. I thought this was odd, but thought maybe something was wrong with the key, like a bent contact / connection on the key.
Today the key stopped working altogether, so I removed it and was going to look to see if there indeed was a bent component of the key keeping it from making good contact or going all the way in.
I took a flashlight and shined it down in the open end of the key and SURPRISE......I found a huge piece of lint that filled the width of the USB key and was about 1/8" deep.
I took a paper clip and carefully removed the lint and the key is functioning normally now!
How did the lint get there in the first place? When going to a client's house to review 3D views, etc, I put my key in my jeans pocket. I guess over the years, it just built up.
So...check your keys for lint if you carry them in your pocket!
#2 Yvon Gonthier
Posted 09 November 2015 - 03:22 PM
That's a lot of lint of experience ;o)
#3 Mike Downing
Mike Downing
  • 82 posts
  • LocationPortola, Ca
Thanks Tommy,
Good find.
My problem would start if I carried my key in my belly button :)
Mike Downing
#4 Jim Johnson
Jim Johnson
  • 289 posts
Posted 09 November 2015 - 08:11 PM
Speaking from experience, if your iPhone stops charging, you probably have the same issue.  :)
#5 Sam Morgan
  • 851 posts
Posted 09 November 2015 - 09:16 PM
Interesting...you must have lots of pocket lint!!!  My key has been on my keyring with car keys since 2011 when I lost it once!!!   It rides in my pocket all the time if its not in the computer.  At least now I know what to check first if I ever have a key problem!
#6 Philip Frank
  • 560 posts
Posted 10 November 2015 - 05:37 AM
Mine USB key is also on my keychain, but I always keep the cap on the end of it when it's not plugged into a computer. Haven't had a lint problem since.
Also tagged with one or more of these keywords: softplan key, key, key not working
