SoftPlan 2018 New Features: Walls
Definition
A preview of the Trace Line locations added to display in Wall Definition dialog.
This is the single line that appears as a wall is drawn in plan view.
2018_wall_alignment
Floor Plan Appearance
The default wall definition appear shaded by default.
2018_wall_shaded
Wall Materials can display textured and shaded simultaneously.
2018_wall_shaded_textured
Footings
Footing Information can be added to a drawing via the Auto Label command.
2018_wall_footing_autolabel
All footing information relocated to new the Footing tab on the Wall dialog.
2018_wall_footing_tab
Footings on Hidden walls clean up correctly.
2018_wall_footings_hidden
Footing control is on a per Wall basis.
The size of a footing for two walls with the same Wall Definition can now be different.
A footing can be turned off on a per wall basis.
2018_wall_footings_instance_size
Snap can locate Footings in Drawing Mode.
2018_wall_footings_snap
Materials
Aluminum material added to Wall Definition list.
PVC Lumber material added Wall Definition List.
Transition Option
A Transition Option Added to Wall Materials
Defining wall types can be a very time-consuming activity while designing a house, and, if a wall definition contains a material such as a brick ledge, even more time is spent creating new wall definitions simply to change the height of that one particular material.
One of SoftPlan 2018’s most time-saving additions is a new “transition” option that is available in the Wall Definition menu. This option provides a convenient method for specifying varying heights for transition materials within a single wall definition and eliminates the need to define multiple walls when the heights of a material should change.
A simple Wall edit allows you to control the height and slope of the transition material so that you can achieve a wide variety of constructions.
This is very useful for stepping walls or sloping the material to follow the grade.
Wall Joins
Wall Joins between different Walls with different materials at different heights improved.
Wall Joins between different Walls with like materials improved.
2018_wall_join_delta_height
Visible Items
The display of bearing and non-bearing walls are controlled separately on the Visible Items dialog.
2018_wall_visible_items_bearing_non-bearing
One Comment
  1. I really like the transition option and the way you can change the footings in the wall edit dialog. Great job!
