Multiple Floor Windows
windows
#1 Jason Fischer
Jason Fischer
  • 16 posts
  • LocationGranger, Indiana
Posted 18 April 2016 - 03:28 PM
When you have multiple floor windows (stairwells, great rooms, etc.), what is the best method to set up the windows so they display correctly in 3-D?  When I set them with an offset for a window that crosses through the floor level (such as in a stairwell), I am able to see the exterior wall material through part of the glass area from the other floor.
#2 Derrik Bauer
Derrik Bauer
  • 256 posts
  • LocationJefferson, IA
Posted 18 April 2016 - 03:48 PM
Not sure if it is the best way, but I use a wall from the upper floor that has a negative elevation.  This allows me to place the opening anywhere on the wall.
Keep in mind if you want to see the wall on the lower floor, you can place a wall then un-check the "Extract in Model" box under the common tab so it doesn't mess up your 3D's.
You can also place a blank opening on the lower wall with the actually opening on the upper wall and adjust the offsets accordingly, but this can be quite challenging....
#3 Derrik Bauer
Derrik Bauer
  • 256 posts
Posted 18 April 2016 - 03:49 PM
Sorry, not "Negative elevation", rather Negative Offset".
Sorry!
#4 Jason Fischer
Jason Fischer
  • 16 posts
Posted 19 April 2016 - 06:29 AM
Thanks, I didn't think about it coming from the upper floor - always tried from the lower floor.  Thanks!
  • 4,574 posts
Posted 19 April 2016 - 08:31 AM
I'd bring the window from the upper floor with a negative offset, but I wouldn't offset the wall. I'd use a cross opening in the wall below, the same as with a garage door. That way you can also dimension to the window on the lower floor plan even though it isn't actually there.
  • Jason Fischer likes this
Also tagged with one or more of these keywords: windows
