Few More Wishes for Softplan 2018
48 replies to this topic
#21 Troy Lachcik
Troy Lachcik
  • 71 posts
Posted 19 December 2016 - 12:23 PM
Here are a few more.
1. More chimney cap 3D symbols
2.3d  timber truss symbols
3. More window trim options to choose from plus sill trim, aprons
4. better roof snap on stacked walls (have the "lollypop" default snap to upper wall on stacked walls)
5. ability to lock header hights from floor to top of header. (not from top of wall)
6. the ability to make a symbol with one command, a box. basically "box symbol" command, without the need to name the symbol. similar to the group command.
7. new command called "truss set" under detail/ section details. this command would work similar to the joist set command but it would be trusses not joists.
......... more to come.
#22 Keith Almond
Posted 19 December 2016 - 12:27 PM
I hope that you're posting these on the Softplan Suggestions page - http://softplan.com/?page_id=818 as well, not just here.
#23 Keith Almond
Posted 19 December 2016 - 04:07 PM
... 5. ability to lock header hights from floor to top of header. (not from top of wall) ...
Not sure what I'm missing here: You can set the floor to top of opening, and you can set the height of the header, what advantage does adding the "top of header height" give you?
#24 Troy Lachcik
Troy Lachcik
  • 71 posts
Posted 19 December 2016 - 05:07 PM
If there was the ability to lock the header height it would move if you changed the height of the wall. unless there is something I am missing I am always moving the windows down every time I change the wall heights
#25 Keith Almond
Posted 19 December 2016 - 06:53 PM
Ahhh ... I see.
I think your missing this ... Under SYSTEM OPTIONS
  • Ben Ginther, Cory Ewing and Tom Rogers like this
#26 Troy Lachcik
Troy Lachcik
  • 71 posts
Posted 20 December 2016 - 03:59 PM
Yes i did miss that. I have tried it and it does exactly what I am looking for. Thank you.
#27 Keith Almond
Posted 20 December 2016 - 08:08 PM
You're very welcome!
#28 randolph cohn
Posted 21 December 2016 - 12:51 PM
in case nobody has asked >
ability to edit the "ends of RAFTER Tails" to have a custom profile
like we can do with beams as shown
left click to enlarge image
I first add auto rafters to the roof with the size I want the beams
and also the spacing "ROOF OPTIONS" set up.
than draw beams where the rafters are and adjust the length and
edit the end profile of the beams.
also edit the beams and "FIT TO ROOF"
note: you can adjust and move the beams around.
note: you can create any custom PROFILE for the ends of beams.
#29 randolph cohn
Posted 23 December 2016 - 11:03 AM
ability to edit rafters (like we can do with beams) to have tails with "profiles"
for now we need to draw a beam with a profile end and replace
delete the rafters and replace with the beams and "edit" the beam
and "fit to roof">
#30 Tom Rogers
Posted 24 December 2016 - 04:42 PM
Ahhh ... I see.
Awesome Tip.  Thanks Keith
#31 Keith Almond
Posted 06 January 2017 - 03:20 PM
I'd like the option to be able to slope a beam by angle or slope (e.g. 6:12) rather than height of top and height of bottom. I know the slope of the reference items, but generally don't know the exact height.
  • Philip Frank, Jim Johnson and Tom Rogers like this
#32 Mark Petri
  • 1,512 posts
Posted 07 January 2017 - 12:28 PM
They've listened in the past. There are always more improvements to be made. I like the previous suggestions. I would endorse Joseph for beta testing!
Here's part of the list I sent to tech a while back. Some are duplicates that I sent at different times...
I would like to be able to add as many area types to each drawing/project.
I would like if I can label the areas for each drawing/project without affecting the system settings
I would like if I could control what information is included in an area label and what format the text is at a drawing/project level.
I would like if I could control what layers are used at a project level.
I would like if I could set up Layer "sets" for different project types at the system level and then choose which layer set I want to use at a project and drawing level.
I was hoping for more overall control so I
could make a default for all window frames to be 3/4" thick and all
door frames 1.5" thick for instance. And, have them in the same plan,
meaning multiple settings at the drawing option and system option
levels. And, really more about the control for the way trim aligns
with the frame, etc. I know in the global settings the thickness and
depth can be set and then adjusted in each instance through the edit
menu. I also could take the time to go through the whole library and
make every setting change opening by opening, but I don't have that
kind of time. I also would like to be able to call out different grill
thicknesses for different openings, and a variety of trim options (for
example; how much trim covers the jamb/frame, unique sill dimensions
per opening, whether the sill sits below the frame or within the frame
and the door is undercut - which is more realistic).
1. I would like to be able to crop in a polgon rather than just a rectangal.
2. It would be nice to be able to control layers visible in custom visibilities.
3. I would like to be able to import PDF files directly into a plan set page.
4. Being able to select drawings, pictures and PDF files and adjust size or size of crop with dimensions entered would be helpful in many cases.
5. Being able to customize drawing labels in their size, shape, text layout and overall look would be great.
1. I would like to be able to select text and choose to align it by center, right or left justification with other text all in one text object (not using crappy multi-text which creates an image that prints poorly and gets jumpy).
I would like to do a bunch of different line types. Some that would be
especially helpful in simplifying things I already do work arounds for would
be lines with arrows in them, lines to represent insulation batts (boxes
work sometimes, but get messy at angled intersections and curves), lines
with characters, lines with dots, all dots, dots and dashes, lines with hash
marks, lines with zig zags. Cloud type lines might be nice as often
revisions we cloud are not rectangles and we don't want revision ID's or
markers on them.
I would like to save all rendering settings for each elevation and for each rendering view file. That way, when I click to regenerate a rendering in a plan set it is the correct sun setting, the correct ambient light, etc. As of right now, the sun is whatever it was left at the last time a rendering was generated. Which doesn't help when the settings were changed for a view from a different side of the building.
3) we ought to be able to tell siding to follow a pitch or grade separate
from the rest of a wall. I have very few jobs that are on flat sites and it
looks horrible unless I spend a ton of time cleaning up renderings and
elevations. I\'ve been told in the past to do 2 models (1 for 2D and 1 for
3D). That's crazy and doesn't make sense for any changes during the design
process.
4) We should be able to change frame thicknesses, what trim snaps to and the
like with each opening, not globally on a drawing. Much more control over
the details of openings and trim would be helpful!
13) Is it too much to ask to be able to clip or clean up a rendering
background and other elements right in SV? Maybe that is going beyond the
call??
15) I have unchecked label and marker (everything I can anyway) in System
Options and, still, when I bring an elevation or section into a plan set
sheet it adds a marker. I want to be able to turn that all off and not have
it show. Or, better yet, have total control over the look of labels and
markers so I can set it the way I want.
16) I would like to be able to crop drawings in plan sets with any shape or
manipulation of that shape I want. The way it is now we are so restricted to
a box.
I have done some recent designs with SIPs. The things that would be huge improvements for SIP design is being able to define a roof profile just as we can with walls. The ability to place framing where we want in the panels would also help. I think it is generally easy with walls, but would be nice to have more flexibility with roofs. Also the ability to set the wall outside of the floor system, to show electrical boxes in the panels (I think we have a way to show that now in profile or framing mode) and the ability to miter walls to roof panels and joints with splines would all be big improvements. I am sure I can think of others and will try to keep a list as I am working on future SIP designs.
#33 Keith Almond
Posted 10 January 2017 - 12:51 PM
Have you tried this one ....
#34 Mark Petri
  • 1,512 posts
Posted 10 January 2017 - 02:17 PM
Yes - it looks horrible in my opinion.
Another one- I would like a lot more options for what shows and how the parts of stairs interact. My competitors have much more control with the programs they use. SP needs to step it up big time with stairs.
#35 Brad Graber
Brad Graber
  • 295 posts
Posted 10 January 2017 - 02:22 PM
And railings, Interior stairs and railings I just draw with lines.
#36 Keith Almond
Posted 10 January 2017 - 02:39 PM
Sorry Mark, I meant have you ensured it's UNCHECKED. I agree ... All the auto labels look terrible. I like to use my labels, worded the way I want, In a font I select, in a location that I select.
#37 Mark Petri
  • 1,512 posts
Posted 10 January 2017 - 02:59 PM
Agreed Keith. Yes, I have it unchecked. The section lines look bad, the whole thing is pretty useless the way it currently is. Took me awhile to get the system to clean up the way I like it and to have my drawings set up the way I like. I sure wish they'd give us a lot more control over such things. Things as simple as line styles - (I know we can hack the program) I wish we could define line styles, add characters, add arrows, etc. within the program without hacking it.
#38 Keith Almond
Posted 12 January 2017 - 10:05 AM
I have wanted "LAYER MANAGEMENT" as you call it and have made product suggestions for the last two or three Versions. I want to manually be able to sort and arrange layers as I want them. Hasn't happened yet and I'm not holding my breath that it will be done in the next version. It seems like layers is just the red headed stepchild!
Looks like you may have your wish granted Warren ... See http://softplan.com/...an-2018-update/
  • Warren Ducote likes this
#39 Keith Almond
Posted 12 January 2017 - 10:09 AM
Agreed Keith. Yes, I have it unchecked. The section lines look bad ...
Another petty peeve of mine ...
I agree the section lines look bad, and because of that I don't use them EVER. Every time I add a drawing to a Plan Set though I get ...
EVERY time, is there any way to avoid this?
#40 Warren Ducote
Warren Ducote
  • 274 posts
  • LocationMontgomery, Texas
Posted 13 January 2017 - 08:09 AM
Oh happy day!!!!!!
