STOP ... STOP ... STOP Moving my walls.
15 replies to this topic
#1 Keith Almond
  • 5,298 posts
Posted 17 June 2019 - 06:33 PM
When I take wall joins down to 0.5" or even ZERO, and remove my walls from cleanup, under no circumstances should Softplan EVER adjust them. I have a confluence of exterior walls where three walls meet at different heights, where a single storey 10:12 pitch meets a two storey 5:12 pitch, and have adjusted then so that they meet BEHIND a 90" corner trim symbol. Every time I open the drawing or edit the drawing, Softplan decides that these walls HAVE to meet differently than I have left them and leaves a gap between the wall and the trim.
LEAVE IT ALONE ... I've lost count of the number of times I've had too put this wall back where I want it.
I hope this is better in 2020 ... when we finally get round to using it!
  • Brad Graber, Bernard Toews, Allen McDonnell and 1 other like this
#2 Brent Hyndman
Brent Hyndman
  • 1,675 posts
Posted 17 June 2019 - 06:38 PM
Please be sure to send us a ticket and outline where the issue is so we can take a look in both 2018 and in version 2020.
Thanks Keith.
  • John Jones likes this
#3 Mark Petri
  • 1,871 posts
Posted 17 June 2019 - 06:48 PM
I have the same problems all the time with close wall intersections. I will try to remember to send a ticket as well next time I a project with such issues.
#4 Steven Kirchoff
Steven Kirchoff
  • 116 posts
Posted 18 June 2019 - 06:03 AM
If there is a fix to this problem I would like to know it. The same thing happens to me.
#5 Brad Graber
Brad Graber
  • 296 posts
Posted 18 June 2019 - 06:11 AM
It happens all of the time with beams and walls connecting as well
#6 Allen McDonnell
  • 1,208 posts
  • LocationIllinois
Posted 18 June 2019 - 06:44 AM
Yes, i agree.
#7 Bruce Donelson
Bruce Donelson
  • 30 posts
Posted 12 July 2019 - 11:42 AM
Walls and beams. Putting them on a special layer and locking the layer seems like the only hope. But then you can't "edit" them to see how tall they are of find out anything else about them.
I can never figure when they will move, either. I will be in floor mode or roof mode, and come back to find that my walls have all jumped around. Running 2018 here, don't know if it is any better with the new version. Any 2020 users like to weigh in?
#8 Jason Bishop
Jason Bishop
  • 306 posts
Posted 15 July 2019 - 09:40 PM
2020 is the same. I end taking the join tolerance on walls and beams down to zero, creating a “line” at the intersection. Looks are not the best, but it’s better than the walls moving completely.......it still sometimes has some weird “overlap” shadow of wall........
#9 PAUL LADNER
PAUL LADNER
  • 77 posts
Posted 23 July 2019 - 05:49 PM
I've also had the same problem.
Very frustrating and time consuming.
  • Allen McDonnell likes this
#10 Kerry Calvert
Kerry Calvert
  • 84 posts
  • LocationCanada
Posted 17 July 2020 - 09:13 PM
This is an extremely annoying issue in both 2018 and 2020
What is the point of turning Cleanup off if Softplan can over ride your wishes any how?
#11 Kevin Rabenaldt
Kevin Rabenaldt
  • 391 posts
  • LocationSan Antonio
Posted 18 July 2020 - 04:40 PM
Yes, I agree.  Thought anchor was going to be the solution.  They need a "lock" command that you can use on two or three wall (or whatever), and they do not move.  If it give problems later because you actually want to move it and don't remember (or come back months or years later and have forgotten) there be a command to show lock walls.
#12 Dennis Hilborn
Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 19 July 2020 - 08:49 AM
This is an old thread and an old problem that keeps happening.  It is similar to the roof moving problem and it was pointed out/suggested that ctrl c will often clean up the roof moving problem.  Have you tried that on the walls moving problem/
I have not noticed any of my walls moving but probably because my houses are mostly rectilinear and I don't usually have problem corners.
#13 Denis Reis
Denis Reis
  • 93 posts
Posted 20 July 2020 - 09:10 AM
Same problem here! Always have to fix/correct this issue
#14 Denis Reis
Denis Reis
  • 93 posts
Posted 20 July 2020 - 02:22 PM
This is what I have to struggle with. Both beam & retaining wall tolerance set to 0 and it still interferes with the wall corner
#15 Dennis Hilborn
Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 20 July 2020 - 04:07 PM
Framer's drinkin on the job again?
#16 Kerry Calvert
Kerry Calvert
  • 84 posts
  • LocationCanada
Posted 20 July 2020 - 05:43 PM
I have been dealing with this for years and unfortunately I cannot figure out a solution.
