AREA/ SQFT
17 replies to this topic
#1 Jonathan Barto
Jonathan Barto
  • 146 posts
  • LocationPittsburgh, Pa
Posted 26 August 2019 - 09:35 AM
Question (unless I'm missing something)
Why does softplan not have the ability on the plans set pages to add area's..   So say in my model it has first floor and a second floor.   So I trace out the first floor sqft and also the 2nd floor sqft.
There is no way to add up the total sqft and show that..
I have to create and area called total sqft and trace that out on the first and second floor.   Then also trace out "first floor area" and "second floor area"
On plans set: (example of what I want to show and auto update)
Total Finished 1500 sqft
First Floor 1200 sqft
Second Floor 300 sqft
Garage 400 sqft
This seams like such a basic function that should be there in Softplan.   And is there in alot of other cad programs..
Again unless I'm missing something on how everyone uses areas while using plan sets.
Jon
  • Heath Foster likes this
#2 Ron Sirolli
Ron Sirolli
  • 304 posts
Posted 26 August 2019 - 10:37 AM
i can not under stand when you edit a wall there is no sf in that area but when you edit a roof it gives you the sf of roof area
i would like to have that on exterior wall
#3 Steve Vens
Steve Vens
  • 202 posts
Posted 04 September 2019 - 01:38 PM
You can create a simple SoftList Report to run these calculations for you. There is much more flexibility with SoftList compared to the automated Schedules. Once a custom SoftList report is created, along with a matching Layout, the report can be inserting into a drawing file by selecting File > Import > SoftList Report. Our Friday Fundamental from August 9, 2019, also covers a similar report that was created to list exterior surface areas of walls and roofing.
  • John Jones, Heath Foster, Raymond W. Johnson and 2 others like this
#4 Raymond W. Johnson
Raymond W. Johnson
  • 4 posts
  • LocationChoctaw, Okla.
Posted 05 September 2019 - 02:03 PM
Thanks Steve.  I have been using the same procedure as  Jonathan.
#5 Richard Rubinski
  • 698 posts
Posted 05 September 2019 - 03:01 PM
Garage 400 sqft
Jon
Jon,
I save a Drawing called "AREA" generate the Area Schedule there, add it to the Model. When you add your area's to each drawing in the model the Area Drawing updates, then add the Area Drawing to the Plan Set page you want included on.
Bill Wimberly from SoftplanTuts told me how to do this.
Rick
  • Attached File  Area.JPG   90.61KB   8 downloads
  • Rick Kingsbury, Steven Wohlgemuth and David Zawadzki like this
#6 Dave Pazyniak
Dave Pazyniak
  • 403 posts
Posted 06 September 2019 - 09:17 AM
Rick, are you covering the same space multiple times with different areas?  I do something similar to this, but I need to have my first floor as a separate area, and as part of the heated area, and as the under roof area...
#7 Richard Rubinski
  • 698 posts
Posted 06 September 2019 - 01:29 PM
Yes, I'll insert the first floor heated, then copy that area, then edit it and make Total Heated Area so it will add multi floors together.
#8 Dave Pazyniak
Dave Pazyniak
  • 403 posts
Posted 06 September 2019 - 01:55 PM
Thanks.  Copy and edit is sometimes easier than tracing some spaces. I did not think of that!
#9 Edward Shannon
Edward Shannon
  • 157 posts
  • LocationDes Moines, Iowa
Posted 17 September 2019 - 10:44 AM
Quick question for this thread.  How do I assign names to the areas (Change "Area 2" to "Addition") while still keeping the area schedule live?
#10 Keith Almond
Posted 17 September 2019 - 11:23 AM
Edit Area, and Change "TYPE" to "NEW AREA TYPE" and name to suit.
  • Edward Shannon likes this
#11 David Zawadzki
  • 736 posts
Posted 17 September 2019 - 01:26 PM
Jon,
Rick
I nominate this for the  Post of the Year award!
#12 Richard Rubinski
  • 698 posts
Posted 17 September 2019 - 01:47 PM
David, glad you like it. It works well for me. Again as I said above Bill Wimberly @ Softplantuts showed it to me. Things like this would be nice in a Tricks & Tip forum.
Rick
#13 Paul James
Paul James
  • 251 posts
Posted 17 September 2019 - 02:26 PM
 System Options- Finishing Options- Area Options, to rename or add areas for new projects. And under Projects Options- Finishing Options- Area Options, to rename or add for existing projects.
#14 Keith Almond
Posted 17 September 2019 - 07:15 PM
Under 2020, you can add new area's on the fly (with NEW AREA TYPE), you don't have to set them up beforehand.
You can also ADD new SOLIDS the same way.
#15 Jon Davis
Jon Davis
  • 543 posts
Posted 18 September 2019 - 06:21 AM
If you're using plan sets, and you're floor plans are on the same sheet, you can put the area schedule on the plan set sheet and it will add up total area's you have in the model.
Using different area's from the tab that Richard posted above, it should list any of them you have in the model in the schedule. So as long as you have an area that you mentioned in the model, it would add up and show in that schedule. Only works if both floors are on the same sheet though.
#16 Richard Rubinski
  • 698 posts
Posted 18 September 2019 - 07:19 AM
Jon, They don't have to be on the same sheet, just in the Model and select "Drawings in Model" when you edit the Area Schedule not "Current Drawing".
Rick
  • Jon Davis likes this
#17 Jon Davis
Jon Davis
  • 543 posts
Posted 18 September 2019 - 07:23 AM
Rick
Sweet!
#18 Edward Shannon
Edward Shannon
  • 157 posts
Posted 18 September 2019 - 07:41 AM
Thanks all!
