I have some custom symbols from over the years in a SP drawing.
I can see them in the drawing library.
They are not in the system library.
Is there a way to import symbols from the drawing library to the system library?
Posted 10 September 2019 - 02:30 PM
Posted 10 September 2019 - 04:40 PM
Tom, here it is in the Help Menu.
Rick
Posted 12 September 2019 - 08:55 AM
The "One Step button" is only available when you open the "System Library". Not the "Drawing Library" as SP Help describes.
Opening the "System Library" clicking on the "One Step"button only give you the "Draw Box" option.
Now what?
Posted 12 September 2019 - 09:51 AM
Now what?
From the Drawing Library where your old symbols are click on ADD
Posted 12 September 2019 - 10:02 AM
Now what?
Here is one from a Drawing that Randy Cohn had sent me years ago. The only thing is you don't have control of the folder where in the System Library it's added.
Posted 12 September 2019 - 10:19 AM
Now what?
I just tried it within the System Library do the One Step and Draw a box around the symbol you want to add, it will add it to the folder you selected prior to selecting One Step. I thought you had to explode the symbol before you could add it. I learned something new today.
The attachment I posted first doesn't make any since after I tried it.
Posted 12 September 2019 - 10:53 AM
Thanks for trying Richard, but none of those options do what I am trying to do.
It would be real easy to just copy the .spy file from the drawing file except you can't do that.
I assume it referencing a previous instal I have since removed, which sound impossible if it's removed.
When I try "System Library do the One Step and Draw a box around the symbol" I get "
Would love to know how to get the .spy file out of the old drawing so I can just copy it to the appropriate directory in the install folder tree.
SP08.jpg 91.03KB
0 downloads
Posted 12 September 2019 - 11:05 AM
This method does works with a little creativity.
One at a time I was able to use "Add Symbol" method, then with two file explorer windows open, one with "spy" file in search sorted by date modified, move it to the other (my prefered folder in current SP install).
Posted 12 September 2019 - 11:11 AM
Click on One Step then Draw a box around the symbol on your drawing screen. See if that works. Maybe you didn't draw a big enough box around the symbol.
Edited by Richard Rubinski, 12 September 2019 - 11:12 AM.
Posted 12 September 2019 - 11:58 AM
Did that. "referencing a previous instal I have since removed" see image in post above: Posted Today, 12:53 PM.
Anyway the Posted Today, 01:05 PM was way faster. I was able to do 40 plus symbols in less than 30 minutes.
Posted 12 September 2019 - 12:20 PM
Glad that worked. I wish that method they would let you pick a folder to put it in.
Mark Petri showed me the ADD button.
Rick
Edited by Richard Rubinski, 12 September 2019 - 12:21 PM.
SoftPlan →
SoftPlan 2014 →
Solids not visibleStarted by John Hondrogen , 20 Feb 2021 ![]() |
SoftPlan →
SoftPlan version 2020 →
Is it possible to just insert symbols into Plan Set mode?Started by Bradford Rainey , 07 Feb 2021 ![]() |
SoftPlan →
Textures in renderingsStarted by Mark Petri , 18 Feb 2020 ![]() |
SoftPlan →
SketchUp - How To Import?Started by Douglas Whitted , 01 Nov 2019 ![]() |
SoftPlan →
Billboard Symbols Turn Off Point to CameraStarted by Tom McConnell , 16 Aug 2019 ![]() |
