Change roof pitch on one side of gable
roof
#1 Warren Taylor
Warren Taylor
  • 9 posts
Posted 16 October 2019 - 08:36 AM
Hello everyone and appreciate any help.  I'm new to Softplan (using about 2 months) and modifying a plan for my own home build.  The front overlapping gables both have a change of roof pitch about 2/3 down on the right side.  I have not found a suitable way to replicate this in Softplan .  Any suggestions?
I've attached both pictures (as designed in Softplan so far) and as built showing the angled right side of the gable roofs in front.
Thanks for any help
Warren
#2 Jon Davis
Jon Davis
  • 543 posts
Posted 16 October 2019 - 08:53 AM
Right click on that edge of the roof, edit edge, and change type to double hip and then input the bottom and top pitches, and the length of the bottom pitch.
#3 Warren Taylor
Warren Taylor
  • 9 posts
Posted 16 October 2019 - 09:08 AM
Oh wow - that worked.  I kept playing with the distance and pitch and got the look I'm after.  One mistake I kept doing is clicking on the roof front and selecting edge thinking the "edge" is the same for all edges.  Not true - each edge can be selected separately.  Thanks for the tip!
Warren
  • Jon Davis likes this
#4 Jon Davis
Jon Davis
  • 543 posts
Posted 16 October 2019 - 11:14 AM
yep. each edge can be edited independently of each other. Works great when you need 2 different pitches like where you have a wrap around porch
where the sides are deeper than the front, or vise versa and you still want the ridge to meet at the corners at the top.
We sometimes do what my boss calls a french hip... And You can make the roof look correct in the model using double hip. The last 16" (basically the over hang) has a lower pitch
all the way around the house.
#5 Tom Rogers
Posted 28 October 2019 - 09:44 AM
Just a little friendly advice on your garage and its proximity at the front of the house.  Your driveway will be tight up to the house and depending on your site you may have some water run off issues and/or turn around when backing out.
#6 Gary McKeon
  • 642 posts
Posted 28 October 2019 - 11:13 AM
"may have"? should say "guaranteed to have". For sure need to revise this area. Good call Tom.
Also tagged with one or more of these keywords: roof
