Placing house within siteplan
Site plan adjusting moving building
11 replies to this topic
#1 Jay Johnson
Jay Johnson
  • 40 posts
Posted 17 February 2020 - 10:20 AM
Hello,
We designed and constructed a project on an acreage lot.  We are getting more into 3D modeling and I want to try to do some shot points, adjust topography, import Google Earth topography, etc.  Historically, I've only used siteplan in a somewhat generic form to label approx. water lines, utility easements, etc.
I'm have entered all the site lines based on the engineer's plat map.  I adjusted site line lengths, bearings, etc.  It all looks accurate but I can't get anything to adjust, for the life of me, to place the building where we actually built it.  Here is a better explanation:
1.  I created a building outline and I was able to place the building outline in the site polygon on the site plan tab. When I place this plan at the bottom of the model stack, it does not show up in the model and all I see is my project floating in blue sky background (in space basically).
2.  When using the site plan mode in the main floor plan drawing, I can't move the building within the site plan, rotate it, etc.  The site polygon sits below the building and when I moved them now I have all sorts of messed up things in 3D (baseboard extending into space, tray ceiling floating outside the house, etc.).
I was just wanting to create the actual siteplan and place the as-built house on it to show the rendering vs actual construction on our website.
Any advice?
Thanks!
#2 Jon Davis
Jon Davis
  • 543 posts
Posted 17 February 2020 - 10:26 AM
Start with using reference points for each floor stacked in the model.
If you're editing the elevation of the site plan, you'll need to make sure the house it set at the right elevation as well.
#3 Jay Johnson
Jay Johnson
  • 40 posts
Posted 17 February 2020 - 11:35 AM
Jon Davis: Thanks for the reply, I appreciate it.  I currently have reference points to appropriately align the main floor with the basement.  Do I need to insert one in the site plan for that same reference corner as well?
  • 5,298 posts
Posted 17 February 2020 - 11:40 AM
Yes. You can adjust the buildings position on the site by moving the reference point.
You will also want to go into the site plan and go to DRAWING OPTIONS > SITE OPTIONS and CHECK to box for BUILDING POSITION and adjust the ELEVATION OFFSET to suit
#5 Jay Johnson
Jay Johnson
  • 40 posts
Posted 17 February 2020 - 12:36 PM
Here are a couple screen captures showing the simple site plan (building outline and site lines).  Also shown is the 3D textured image where the ground is nowhere to be seen.  Any ideas as to why?  I did check the building position box and it doesn't seem to matter where I set the offset, I can never see the ground on this one.
  • Richard Rubinski likes this
#6 Henry Buckner
Henry Buckner
  • 342 posts
Posted 17 February 2020 - 01:12 PM
Check extraction options and make sure "site polygons" is checked.
#7 Richard Rubinski
  • 693 posts
Posted 17 February 2020 - 01:19 PM
Did you add the site plan to your model?
#8 Jay Johnson
Jay Johnson
  • 40 posts
Posted 17 February 2020 - 01:29 PM
Thank you for the replies.  Yest, the site plan is added to the bottom of the model stack.  Also, yes, the site polygon is selected under extraction options.  Still can't figure it out.  Thanks.
#9 Keith Almond
  • 5,298 posts
Posted 17 February 2020 - 01:36 PM
Is it a closed polygon?
#10 Richard Rubinski
  • 693 posts
Posted 17 February 2020 - 01:45 PM
Click on the Auto Horizon to see if you get grass under your model
#11 Richard Rubinski
  • 693 posts
Posted 17 February 2020 - 01:55 PM
After looking at your screenshot, your building outline is shaded showing its a polygon, but the site isn't. The Sites not closed. Zoom in to each corner to see if there're connected. SoftPlanTuts has some good tutorials on Site Plans.
https://softplantuts...l-category/Site
#12 Jay Johnson
Jay Johnson
  • 40 posts
Posted 15 March 2020 - 07:07 AM
It turned out the site was just barely not closed.  Thanks to all!
Also tagged with one or more of these keywords: Site plan, adjusting, moving building
