Textures in renderings
Textures Renderings SoftView Symbols Options
7 replies to this topic
#1 Mark Petri
  • 1,872 posts
Posted 18 February 2020 - 07:21 PM
Is anyone else finding that most symbols are not allowing the rotation or adjustment to texture settings? I have several timber symbols and accents I use in a lot of projects that do not properly texture. I've also noticed it with some doors and other more detailed parts of the model. When I adjust the size of the texture, or set the rotation it does not respond or change from the original setting. I've tried every sort of variation and cannot get most of the option settings to make actual changes in the renderings (using texture or render mode). If I want to change the scale or orientation of the texture I am out of luck.
Let me know if you are also having trouble with editing textures in symbols while in SV.
Mark
#2 Tim Stockton
Tim Stockton
  • 343 posts
  • LocationWichita, KS
Posted 25 February 2020 - 02:27 PM
I'm having the same issue.  I opened a ticket with support and they are aware of the problem.  It seems that models made in SketchUp and then brought into SP won't texture correctly.  Hopefully there will be a patch out soon correcting this.
#3 Michael Roman
Michael Roman
  • 121 posts
  • LocationPeshtigo, WI
Posted 26 February 2020 - 06:29 PM
Same here.  I have noticed for a while now.  I hope they have a fix soon!
#4 David Johnson
David Johnson
  • 74 posts
  • LocationSioux Falls, SD
Posted 21 April 2021 - 08:36 AM
Did anyone here ever get a fix for this issue? I have been having this problem too, and after reading this post I realized that is exclusive to my SketchUp models.
#5 Mark Petri
  • 1,872 posts
Posted 21 April 2021 - 10:10 AM
I haven't paid attention to it in a while. I'll have to test it out again when I use some SketchUp symbols in a current project.
#6 Heather Payne
Heather Payne
  • 1 posts
Posted 27 September 2023 - 09:02 AM
Was there a fix for this issue?  I am having this issue with my SketchUp symbol downloads
#7 Mark Petri
  • 1,872 posts
Posted 27 September 2023 - 08:26 PM
Me too!
#8 Bill Wimberley
Bill Wimberley
  • 619 posts
  • LocationSan Angelo, TX
Posted 02 October 2023 - 07:10 PM
I did a tutorial about how to texture models in Sketchup for use in SoftPlan. It was done for SP 2012 so the interface is a little different now but the concepts still apply. I have a number of models I created in Sketchup and use all the time in SoftPlan. The brick stairs and colums below are Sketchup models. The trims above the windows and door are Sketchup too.
The tutorial is in 4 parts:
  • Steve Haarmann and David Zawadzki like this
Also tagged with one or more of these keywords: Textures, Renderings, SoftView, Symbols, Options
