Has anyone experienced this? If I press ctrl and highlight the areas I wish to move as a block, the minute I click or press home to start moving the highlighted block everything disappears until I click or press home again. The block moves, I'm just totally blind until I click again and it reappears. Unless I type in a dimension to move there's really no way to tell where it's going to land and I just hope it's in the right place.
Posted 29 April 2021 - 09:08 AM
Yes it happens with ctrl picking. Text ctrl picking drops text NOT where its supposed to go most of the time also....which is more annoying.
2022.2.7 update may have corrected this issue...difficult to determine.
#5
Posted 03 May 2021 - 06:55 PM
No this was not corrected in the update unfortunately. Can replicate on every drawing.
#6
Posted 03 May 2021 - 07:20 PM
Apparently, the 2022.2.8 update was released today. Try that!
Posted 04 May 2021 - 10:15 AM
I have experienced the same problems and some items that I am not moving disappear and do not reappear with a general cleanup. I often have to close that drawing, sometimes the whole project and reopen it to clear the display error. I've reported it to SP Help and they've sent it on to the development team. I would suggest the same as the more who do, the more likely it is to be corrected in the software.
Heather Baldwin, AIBD, CPBD
heather@baldwinlakedesigns.com
(801) 652-3117 Cell
#10
Posted 18 May 2021 - 07:43 PM
if we're talking about the same thing, this is still a a problem. CTRL-picking then moving or copying the insertion point jumps around. Sometimes it works and other times it does not. I created a ticket on this already. i have the issue mostly with copying shapes or text....the insertion point is not accurate when placing the copied item.
Is anyone else continuing to see this? i've created another ticket #67918 just now. thanks
#13
Posted 19 May 2021 - 09:54 AM
Ticket Number: 67918
Chris,
Can you please create a support ticket so we can take a look.
#16
Posted 19 May 2021 - 12:34 PM
Joseph,
We were able to recreate your issue using the drawings associated with ticket 67918. CO 53906. This only seems to happen when you are using Visible Items->Display Print Pen Style.
Unchecking that option should fix your issue in the interim.
display_print_pen_style.png 27.88KB 2 downloads
- John Jones and Joseph Smith like this
#17
Posted 20 May 2021 - 01:11 PM
wow, i never would have figured that. ok thank you!
Also tagged with one or more of these keywords: Block move
SoftPlan →
SoftPlan 2016 →
Block Move - Dimensions off by 1/32Started by Tom McConnell , 09 Aug 2015 Block Move, Dimensions off |
