Scissor Gable
#1 Ben Ginther
Ben Ginther
  • 141 posts
  • LocationSaskatchewan
Posted 28 January 2015 - 04:23 PM
Hi,
  I want to use scissor trusses over a covered deck. How do I draw the gable? I have tried using a separate wall but I cannot rake the bottom and fit to roof. Both the "Rake Bottom - Position" and the "Wall Height - Multi Height" stay the same. They do not change when you try to edit them. Any ideas?
Ben
#2 Yvon Gonthier
Posted 28 January 2015 - 04:44 PM
You have to draw 2 walls because you can only slope the bottom in one direction, it won't adjust as a "V" on the bottom. By drawings 2 walls end to end, you can slope the bottom of the 2 walls individually up toward the peak. Use ceiling (gable) to create your soffit.
#3 Yvon Gonthier
Posted 28 January 2015 - 04:47 PM
Or, if you want only one wall, create a triangular arch (blank) and insert to fit at the bottom of the wall.
#4 Ben Ginther
Ben Ginther
  • 141 posts
Posted 29 January 2015 - 01:04 PM
Thank you!  Although I have successfully done this in the past, I could not edit the two walls this time. I tried shutting down and restarting SoftPlan but still no luck. However, the next day all works well.
Thanx again.
Ben
#5 randolph cohn
Posted 29 January 2015 - 02:56 PM
the easiest way to draw a scissor truss is to draw a cathedral ceiling to create the sloped lower chords
and of course the roof creates the sloped upper chords.jpg scissor truss over terrace.JPG
Posted 29 January 2015 - 03:46 PM
I think the issue was more the profile of the end wall than the trusses themselves randy. The roof gable still wants to be flat bottomed!
