Auto Dimension
Improvements made to Auto Dimension when the Include Interior Walls option is selected.
Dimension Point
Settings in the Dimension Options for Shapes are considered when placing Dimensions via the Dimension Point command.
Disto
Dimensions can be input directly from Leica DISTO measuring devices.
Draw Select
Dimensions and Dimension Lines are much less prominent when using the Draw Select command. This change is particularity noticeable when working in congested areas of a plan which makes it much easier to select the desired item.
Repeat Edit
Repeat Edit changes Dimensions with Show Text enabled.
Roof
Extensions and Dimensions can be pulled from either the Edge or Center of a Beam.
Rounding
Round to Nearest option added to the Edit menu of dynamic Dimensions.
