SoftPlan version 2020 New Features: Floor System Posted on June 14, 2018February 27, 2019 by admin Building OptionsAdding a Hole to a Floor System only cuts the hole through items on the active Building Option. DimensionsFlush Beams in a Floor System can be Dimensioned directly. Dimensions on structural slabs update as edges are adjusted. GrilleFloor Grille command added. LevelFloor System Level selection added to the toolbar allowing the Level to be selected prior to placing the items. Slab FootingReverse a Slab with Footings properly maintains the footing joins. Slab RecessDimensions can be added to Slab Recesses. Dimension override fields added to Slab Recess, user can specify sizes independent of the wall above. OWSJOWSJ Floor Joists default to be chord bearing. Plumbing DropsExtensions and Dimensions can be added to Plumbing Drops. PostsDraw Post command available directly in Floor System Mode. Reference EdgeSet Reference Edge command added to the Right mouse click on Joists. System/Drawing OptionsOWSJ and Top Chord Bearing Truss types added to System/Drawing Options>Floor System Options.
Do slabs still show triangular “skirts” at the top. Never could figure those out, never could get rid of them.
