Cabinets
Cabinet Lighting added to SoftList.
Ceiling
Variables added to calculate for Tray Ceilings:
has_profile
tray_finish
tray_thickness
tray_height
Excel
Waste Column added to the Excel Export.
Finish Options
The order of Finish Options in SoftList is consistent with the Finish Options list in the System Options.
Labor Markup
Labor Markup added to apply a multiplier to the Labor value separate from the Cost value. The old Markup value is renamed Cost Markup.
Openings
jamb_size variable added. Used to differentiate openings in a 2x4 wall from openings in a 2x6 wall.
Opening Trim
Constants vinyl and stucco added to the Opening Group.
Rod and Shelf
rod_count variable added, returns number of rods.
Shadow Board
shadow_board_thick variable added.
shadow_board_height variable added.
Site
surface_area variable added, returns surface area sloped site polygons.
Trim Board
The variables treatment_width_start and treatment_width_end added.
Truss
Constant vertical added to Group Roof Truss
Truss Pitch lists on SoftList Report.
User Variable
Measure type added to User Defined Variable.
