AutoCAD
Import and Export .DWG 2018 format added.
AutoCAD drawings with Layers containing Unicode characters import into SoftPlan.
Import of AutoCAD drawings with very complicated Symbols improved.
Invisible text is NOT imported from an AutoCAD drawing.
PDF files contained in a drawing are included in the DWG export.
Plumbing Drops and Electrical Connects do NOT export.
Import Image file resolution is maintained, formerly images were converted to a maximum 1024 x 1024.
Mitek
Export of drawings to Mitek containing very short walls improved.
Model
Drawings in the model are automatically loaded into memory resulting in increased performance for some operations.
Images located on a Layer set to Fade will appear faded when exported to a PDF file.
Lumion
Direct export to Lumion added, via a .FBX file.
Available to SoftPlan+ subscribers only.
Plan Set
PDF Import added to Plan Set.
Projects List
Right click on the SoftPlan icon button on the Windows taskbar displays a list of recently used projects.
Save
If a Cleanup is the only command executed in a drawing session a Save Drawing prompt will appear.
Lock Open Project
If a SoftPlan Project opened from the Start Page is already open a "The Project is currently in use by the following key:" message.
NOTE: THIS ONLY APPLIES TO SHARED PROJECTS, MULTIPLE USERS CAN SIMULTANEOUSLY OPEN A LOCAL/NETWORK PROJECT WITH NO WARNINGS (AND SUBSEQUENT LOSS OF DATA).
SketchUp
Import and Export support added for SketchUp 2018 file format.
Surfaces exported to SketchUp are logically grouped to make modification easier.
Start Page
Last Modified Time displays when cursor is over project name.
Pin Project option added, list the Project at the top of the project list on the Start Page when selected.
Remove Project command added to Right Click, removes the cloud copy, the start page entry, and any published reView files.
The local copy is not removed.
Search command added to the Project section of the Start Page.
Remove Shared Project command added to the Start Page of the user that a project is shared with.
