Auto Basement
Wall change behavior when creating a lower floor via the Auto Basement command enhanced.
Stairs included in generated Auto Basement.
Edit Dialog
Simple calculations can be completed directly in the fields on a dialog box for example: - 6"+7/16" adds 7/16" of an inch to 6" to make 6.4375"
High Resolution Monitors
Higher resolution icons added: 64x64 and 256x256.
Selection Set
Previous Selection command added to the Tools menu or pressing P will recall your last section set.
System Options
Enable Multiple Undo Option removed.
Visible Items
Visible Items on the drawings update in real time when turned off/on from the dialog.
