Edit Dimension can be used to change the length of a Deck Bench.
Beam Schedule
Deck Beams can be added to Beam Schedule.
Deck Post Caps
Deck Rail Post Caps Finish option added.
Stairs
Compound Deck Stair editing improved.
Ramps
Wood framed Ramp command added to Deck Stairs.
5 Comments
Can you guys add a feature to slope the deck surface? Thinking that when one does a waterproof deck and it requires for example a 1/4″ per 12″ of deck for water runoff…it would be great to show that properly without having to draw a solid for that.
Where are you drawing the solid?
On top of the deck joist to create a sloped surface…sloping away from the house toward the edge of the deck or a drain..
Any control on ramp joist depth?
Yes – edit Depth.
