3D
Generation of Site Plans with very large numbers of shot points is faster.
Concrete
Site Work type Concrete added, used for air handling equipment or pool equipment pads etc.
Form Polygon
Edit Form Polygon command provides visual feedback making it easier to see the results.
Google Earth
Import Google Maps Site Data command added imports site terrain from Google directly into the Site in SoftPlan.
Note: This feature is only available to SoftPlan+ subscribers.
Hole
Site Hole command added used to cut a hole in a non-property Site polygon, for example, a hole in a patio to accommodate a pool.
Pens
Site Line Pen setting will Repeat Edit.
Repeat Edit
Fit Site Polygon to Ground command will Repeat Edit.
Shot Points
Extract in Model option added to Shot Point, when selected the elevation of the point will affect the associated site poly regardless of it's new vs. existing setting.
A Draw Shot dialog appears when the drawing action is started, allowing the elevation to be set resulting in a smoother drawing process.
Undo
Edit of Direction of North can be undone.
Water Feature
Site Work type Water Feature added, used for ponds etc.
