I've generated a cross section and saved a drawing of it. The line weights are too thick and the option for print pen - outline pen is greyed out. The texture pen is available to edit. I've looked all over for a system, project or drawing setting for the line thickness. Is there one and if so, where isit?
Cross Section Line Thickness
Posted 13 April 2022 - 12:05 PM
The pens are setup (in all three places) under pen setup. Check CROSS SECTON "X" ITEMS and CROSS SECTION ITEMS in GENERAL ITEMS Not CROSS SECTION DETAILS
Posted 13 April 2022 - 12:28 PM
Keith,
Okay, found it. Cross Section "X" Items were set to a thick pen width. Cross Section Items were set to the pen width I wanted which didn't work. Not sure what is an "X" Item and a regular Item. Still makes no sense to me that if I save as a drawing, that there are lines for which I cannot edit the pen width. Missing something fundamental here I think.
Posted 13 April 2022 - 03:14 PM
Kris,
Quick explanation ... You CANNOT change the pen thickness of ANYTHING on a layer that has a defined pen thickness.
Your options are:
Edit the defined pen thickness of the LAYER in the layer setup OR
Edit the item to be on a layer with a DEFAULT pen thickness, and then edit the pen size independently.
